That Steeda part looks promising, I had something similar on the 06 Vette.
Should be able heat up and change the outlet shape a bit or section it and glue with ABS cement.
Before I saw this I was thinking one could take two pieces of pipe and put in the end up a section of ABS tubing and heat it up to shape it to fit the stock inlet.
Yes, having a junk bin, several sorted out ones...very helpful when building stuff and saves time and money!
I have a ton of odds and ends here from honeycomb sheets, perforated steel I used yesterday to cover the window I just installed in the trailer ramp door on the inside so it can be walked on, DOM, SS tubing and elbows, Aluminum, and boxes of little scraps that get dug into regularly. Also I have hundreds of bolts, nuts, washers, screws.....
