BC Coilovers + Powerflex Spring Pads
San Diego
Does anyone know if BC Coils & the Powerflex Spring Pads are compatible? I have an upper spring pad that came with the coilovers but they dont have that little nipple that goes into the hole like the oem one does ._.
HBEcoBeaST
Huntington Beach
I can't find the post but another member said they had to remove the nipple (on the spring pad) to use it with BCs. I'd double check before ruining your $70 powerflex though.
koozy
Los Angeles, CA, USA
they're compatible and there's no need to cut the nipple, it's just to help keep the pad in place as a locating dowel.
koozy
It’s not necessary, you already have them. Only main difference is it will be thicker which will require the Coilover to be adjusted to compensate and has a dowel. Unless that’s what you want.
