A recent update for any owners of a gfb dv+.....check your box and make sure it has a barcode imprinted into the box. If you don't have this, you most likely have a knock off diverter valve! Just changed mine out, and the off throttle flutter "Turkey call" is now gone and my FiST is now making 18 psi boost at 6k rpm. Before with the knock off valve I would hit 24 psi at 4k rpm then it would dump it down to 10 psi at 6k rpm!?
Sent from my VS985 4G using Tapatalk
