I think it's pretty much agreed by all that this would really only be a large benefit for BT, but even the OEM turbo would benefit from a straight path to the cylinders, especially from a $68 part...
With that being said, after looking closer it doesn't look like it will work, at least not with some form of adapting spacer which would then require special gaskets. Look at the photos of the mount holes above, then compare to this-
Furthermore, to even make this a remote possibility you would have to relocate the oil filter as it sits directly below the TB. The OEM IM looks like the TB mounts approximately 2" below the runners while the FoST IM mounts the TB approximately 7.5" lower. Finally, the FoST IM runners push the IM away from the block far enough that, especially with a spacer, it would most likely not have enough room to fit.
Clearly this is all guesstimation based on a tape measure, the two cars, and some online pictures, but I don't see it being feasible. Ymmv.
Hoods up-
Hoods up-
