If you are just bolt ons and running a flash tune or OTS map you dont need and tune update. But if you choose to run the 93 octane. Running a map for 93 octane will give you better performance. But it is safe to drive on the current tune.
This is a thing of the past and was needed with carbureted fuel systems.
Today's EFI systems use a barometric or map sensor to control changes in atmospheric air pressure.
Yes, you should change your tune based on fuel octane rating.
