https://batteryuniversity.com/learn/article/absorbent_glass_mat_agm
<< ....................... AGM ... charge ... up to five times faster than the flooded version .................................................................. AGM batteries are sensitive to overcharging. A charge to 2.40V/cell (and higher) is fine; however, the float charge should be reduced to between 2.25 and 2.30V/cell (summer temperatures may require lower voltages). Automotive charging systems for flooded lead acid often have a fixed float voltage setting of 14.40V (2.40V/cell); a direct replacement with a sealed unit could overcharge the battery on a long drive. (See BU-403: Charging Lead Acid.) .............................................................. >>
Based on a voltage reading after pulling the battery, I suspect AGM will do fine in our vehicles. If you find or believe otherwise, post-up. Thinking it was low, I did put it on a standard FLA charger with auto-shutoff for a short time and found that the battery was then reading high... and taking a really long time to come back down. Again, this was a probably 20 minutes of charging max and the auto-shutoff was never tripped.
Advance Auto AGM purchase...
https://www.fiestastforum.com/threads/battery-maintenance.17180/post-406509
How to read battery voltage from the dash...
https://www.fiestastforum.com/threa...ould-secret-features-thread.15615/post-406280
