Thanks for sharing this. Jason is one of the more popular tuners for this platform and regularly participates in these forum discussions.
Could these tables be altered by the tuner? I’m assuming the lean means some type of vacuum leak, but why would that go away once warm? And not leak under boost?
edit: also could you share a 101 on open vs closed loop
- Yes, the tables can be altered by a tuner with access.
- If the AFR is actually 15.5 consistently, your fuel trims (Short Term and possibly Long Term depending on how long the AFR is that lean) should be positive showing the ECU adding fuel. Those values STFT and LTFT are important. Before a leak can be declared, the trims must be known. The trims become active shortly after a startup, so you need to monitor them during the whole drive cycle to determine any trends.
CLOSED/OPEN LOOP
Older Vehicle versions. There are additional nuances for the different systems, but these are the main points:
- CLOSED LOOP - On older vehicles the CLOSED LOOP function means the ECU is using a narrow-band O2 sensor as the feedback for the ECU to control the fueling so the AFR remains very near the stoic value of 14.7 for pure gasoline and 14.08 for the more common ~10% ethanol blends. The earliest desire for this control was/is for emissions control. The side benefit for enthusiasts is that the electronic fueling controls are significantly more precise and tunable than carburetors.
- OPEN LOOP - On older vehicles the OPEN LOOP function means the ECU has abandoned the narrow-band O2 sensor feedback and is fueling based on read-only tables with RPM and Airflow as the X/Y table inputs. Although the early closed loop systems were very good at low throttle/low rev fueling for idle and cruise, they couldn't keep up at big throttle/high revs, so the fixed tables were used for real power tuning.
- Many newer vehicles (especially the Ford Ecoboost) use CLOSED LOOP for ALL fueling functions where the ECU uses wide-band O2 sensor(s) to provide feedback to control the fueling such that the AFR is very precisely controlled under ALL running conditions. The Fiesta ST is included here. Although the USDM version FiSTs don't use an actual Mass Air Flow measurement device, the airflow is calculated using throttle position and rpm calibrated with VE. Ford puts a LOT of effort into modeling the Volumetric Efficiency of these ecoboost engines.
So, the Ford Ecoboost ECU calls CLOSED LOOP the same "closed loop", but the OPEN LOOP function is called Optimum Power or Power Demand mode, depending on the ECU. During this "Power" function the ECU is switched from the stoic AFR tables to another set of tables where the AFR targets are set richer to get the "best" power within the stock engine parameters. This isn't to say that more safe power can't be had, just that the Ford engineers must design to a life expectancy where aftermarket tuners can just go for whatever risk they or the customer will assume.
Hope this helps answer "top-level" questions about the FiST ECU. There's obviously a LOT more going on, but this is the basics.
