Track report: 65 F ambient start of first session running modified undertray and air dam extension. PBIR is a 2 mile track with 10 turns, two straights one 4th, one 5th gear. Report Engine Coolant Temp (ECT)/Oil temp
Start logging: 196 F/ 211
Over 7 minutes into session, ECT hit 220.0 F for first time. Oil 242.
8 minutes in, hit 225 ECT for 2 seconds, Oil 245.
Toward end of session logged 50 sec of ECT above 220 and below 225. Oil running 246-47. Total 5 periods over 220, most lasted 10-15 sec. All at high boost/rpm.
During cool down back straight in 5th 208 ECT and 237 oil.
Hot pit exit ECT 201 oil 234.
Max back straight 120 mph at 5540 rpm in 5th.
I was dragging undertray at pit exit, so removed it completely before next session. Fastener failure. Plan was to remove air dam extension first, then undertray. Oh well, removed undertray first instead.
73 ambient start 2nd session
Start logging: 206/214
Six minutes in 220/230
Hit 225 ECT for two seconds middle of session on back straight in 5th, oil 245. Max speed 121.
Exceeded 220 total of 8 times, most 10-15 sec duration, longest period was 25 secs and included hitting 225/247 in middle.
Hot pit exit 201/234
My plan was to remove 2" air dam extension and log that too, but forgot that part of plan when undertray came off first.
50,000 lines of data in spreadsheets, logged fine grain mainly to try to understand TVC action with LSD. But that is another day.
My main takeaway from this track day is do not try to run BFG SC2's for a new personal best when they are already at wear bars. They still stopped well, but lateral grip was lacking. At the end of my last session I spun in exit of turn 9, easiest exit on track, overpowered and lost front traction, and around we went, gracefully if ignominiously.
