I had my wheel bearings replaced and now one of the ABS sensors is out. This shows up as the ABS and traction light being visible when the car is running. I used my Accessport to check to see which side has the bad sensor, and that fault is not showing up in the engine codes. Is there a setting I need to change on the Accessport, or is a bad ABS sensor something that would not show up on an Accessport engine code indicator? Thanks in advance for any advice anyone has.
