I like making these build journals to encourage my project goals. Perhaps you'll follow along?
Epic Test Drive:
I've owned a ton of vehicles (this one is #42) many of them absurdly quick but I've never had the opportunity to really get to know the limits of a car before I bought it. I was fortunate enough to travel to Germany for work this summer and like some of my past trips to Germany I made it a point to stop by the N?rburgring for some track time. It was not even close to reasonably priced (would've been a nice down payment on the car...) but this time I rented a FiST (3 door) from RSRNurburg and did a full track day. Long story short: I was absolutely blown away by how fun the car was and how with reasonably good driving fundamentals it could hold its own against other more powerful cars on the Ring. Needless to say, I was sold and once I returned home I concocted many justifications to sell my money-pit E46 M3 daily driver and pick up a Fiesta ST.
One of my "better" laps that day:
[video=youtube;9ylfqhQ--OY]https://www.youtube.com/watch?v=9ylfqhQ--OY[/video]
My FiST Specs and the Purchase:
Magnetic exterior, Recaros, Moonroof (didn't want), Heated Seats, Nav (didn't need)
Paid: $4500 under MSRP ($2k off from dealer, $2k Ford rebates, $500 military rebate, no trade)
Conclusion: Wanted a stripper but the price was so good I decided to bite the bullet and take the loaded car. This was my top choice for color anyways.
Initial goals for my Fiesta ST
Use: It will be daily driven ~85 miles per day. 3-4 track days per year split with my other toy. If I can find the time with my baby boy and get my wife to quit bitching, I would like to bump that to 1 track day per month as I just can't be satisfied with a few.
Goals for daily use: a little louder, a little lower, a little quicker, increase efficiency for commuting as a side effect of performance, some aesthetics, 2599 lbs
Goals for the track: achieve a track day weight of 2450 lbs full tank of fuel retaining most comfort items, try to achieve reliable engine cooling for full sessions, try to achieve reliable and adequate braking with the stock calipers/rotors, avoid being in the position to point by as much as possible, always be pointed by as much as possible
Mods I am thinking about for the street:
- DONE Muffler delete (a little more sound, stock is way way too quiet for my taste)
- DONE (changed to Maxton) Mountune lower front splitter (Triple R style)
- Wrap or plastidip the silver steering wheel trim, circular silver vent surrounds, and perhaps the silver door handles (I can't stand the cheapo silver and the steering wheel -- major touch point -- is super mopey looking)
- Upgrade shifter boot and perhaps nob to something nicer to touch/look at
- DONE (misc brands) Deadhook motorsports "stg2" performance package (drop in filter, 3" catless DP, intercooler upgrade, Cobb AP, tune)
- DONE Airbox cool air mod and/or snorkel
- DONE Clutch pedal spacer (easier rev matching on the street to keep the skill fresh)
- Clutch pedal stop (way too long for my taste)
- ABANDONED Hard wire clutch safety interlock and brake interlock for starting the car without getting in it (minimize wear and tear on the seat bolsters)
- MITIGATED Figure out how to eliminate that ridiculous double honk when you get out of the car with it running
Mods I am thinking about to achieve the track aspect:
- DONE Lightweight battery
- DONE Muffler delete (weight savings)
- ABANDONED 4x100 re-drilling
- DONE (changed to 17s) Light wheels (thinking 15x9 6ULs or maybe 16s to keep the sidewall flex down)
- DONE (changed to RS-RRs...for now) Track tires (thinking 225s if possible, R888 or similar)
- DONE Lightweight forged Al lugs
- DONE Rotor heat shield delete
- DONE Custom brake ducting
- DONE (completed with both Wilwood & StopTech) Wilwood front brake kit (for weight savings, braking)
- DONE (changed to StopTech standard street pads) Streetable pads (the PFC Carbon Metallic have worked well for me on the track and are $80/pair)
- ONGOING Remove rear seat, spare, possibly passenger seat before each track day
- ONGOING Misc weight reduction focusing on as much free stuff as possible (coilovers, symposer delete, hood insulation delete, rear wiper delete, fog light delete, engine cover, hatch privacy cover, delete user manual, sun visor delete, sunroof blockoff/delete
etc...)
Most Current Photo:
Actual mods to date:
- Cobb AP V3
- Stratified Log-based re-tune
- Mountune FMIC, black
- Cobb RMM
- Cobb filter
- Mishimoto induction hose w/ 2016 adapter
- Depo catless downpipe w/ exhaust wrap
- Shorai 36ah LiFePo lightweight battery
- Motorcraft FL400S oil filter (larger)
- Swift Spec R springs
- Maxton front splitter
- Maxton rear wing extension
- 17x8 Rota Grid wheels
- ARP extended 2.5" wheel studs
- VMS lightweight forged aluminum lugs
- StopTech big brake kit front
- StopTech stainless brake lines front
- Motul RBF600 Brake Fluid
- VHT painted rear calipers
- DDM Slim Ballast HIDs
- Yorkim LED interior and license plate bulbs
- Sylvania 3157A amber front/rear turn signal LED bulbs
- FlashWolves LED reverse light bulbs
- DIY muffler delete
- DIY symposer delete
- DIY brake ducting
- DIY free intake mod
- DIY rear wiper delete
- DIY 3D printed gas pedal spacer
- DIY Misc weight reduction (ongoing)
Weight Savings to Date:
Front:
Lightweight battery: -24.96 lbs (30.12lb OEM, 5.16lbs Shorai 36ah LiFePo)
Delete symposer box, clamps, rubber hose, plastic tubing full length: -0.89 lbs
Delete engine cover: -1.71 lbs
Delete hood insulation and plastic hardware: -1.62 lbs
Remove OEM RMM: -1.32 lbs
Add Cobb RMM: +1.73 lbs
Delete front grill horizontal plastic trim: -0.42 lbs
Delete OEM intercooler: -4.64 lbs
Add Mountune black intercooler: +7.50 lbs
Delete full washer reservoir (-8.00 lbs)
Delete 1 of 2 horns and dual horn bracket (-0.69 lbs)
Delete radiator shroud flaps (-0.15 lbs)
Add Depo downpipe with partial exhaust wrap +5.50 lbs
Delete OEM downpipe, heatshield, mount, hardware: -11.62 lbs
Remove OEM induction hose: -0.90 lbs
Add Mishimoto induction hose w/ 2016 adapter: +1.75 lbs
Mid:
Delete sun visors: -1.45 lbs
Rear:
Delete rear wiper, motor, hardware: -3.00 lbs
Muffler delete, add tips, piping: -15 lbs
Unsprung:
Front OEM shock NVH ballast delete: -2.38 lbs
Rota Grid 17x8 wheels: -12.32 lbs
Remove stock tires: - 76.00 lbs
Add Federal RS-RR tires: +88.00 lbs
StopTech Front BBK: -0.36 lbs
VMS Forged Al lug nuts: -0.77 lbs
Remove stock wheel studs: -1.56 lbs
Add ARP 2.5" wheel studs: +1.96 lbs
TOTAL: -63.33 lbs
Starting Picture of the Car:
Baseline Weight:
Full tank of 93 octane, exactly as delivered by the dealer (manual in glove box, floor mats in, no personal items in car). Love having a set of corner scales!
With me in:
Epic Test Drive:
etc...)
Most Current Photo:
- Cobb AP V3
- Cobb RMM
- Cobb filter
- DIY brake ducting
Front:
Mid:
Rear:
Unsprung:
TOTAL: -63.33 lbs
Baseline Weight:
With me in:
