AC not working after rad replacement
Pittsburgh
Hi all, I just swapped the rad, thermostat, expansion tank, coolant hoses, and intake. Took the entire front end off to do it. Now the AC only blows hot air. The AC did function before but the car would drastically overheat. I’m wondering if I forgot to connect something. Any advice would be appreciated!
D
Deleted member 21349
Guest
did you disconnect the refrigerant lines? if not then maybe you nicked the condenser while removing the front end
Oceanside California
Having the same issue with mine after replacing pretty much all the same parts you did. Charged with refrigerant, holds pressure, compressor engages, but cold air just won't blow.
