I have a 15 FiST with 58k miles. It’s a fbo stage 2 car. I’m running Konig Hypergram 17x8’s with 205/40/17’s, H&R Sport springs, stock struts, and camber bolts.
Soon rear camber plates, new front struts, endlinks front and rear, and rear spring rubber mount/bushings.
After I lowered my car I noticed my drivers side is lower.
I’m a technician, and want a Ford tech for 10 years, and know how to check for things that are bent and everything seems to check out.
Struts aren’t blown in the front but are def getting tired.
From the little I could find most said changing the front struts fixed it(yes I know struts shouldn’t change ride height, springs should. Just saying what I found).
I also have an alignment appointment this Friday and am wondering what specs I should get. I used to have a curvier drive to work so I have the toe out and more camber, but I’m thinking of zero’ing out toe and using less camber. Thoughts?
My end goal is coilovers, but an S280 is taking priority for now.
