UPDATE!
Confirmed, you will soon be able to order the 11.75" BBK to fit over 15x8, 6ul wheels, final test of new caliper mounts and new stock knuckles completed 21APR16.
There may be a 4x108 wheel that will fit if somebody wants to run that bolt pattern it will also be available.
Whew, it was a hard thing to pin down and nobody thought I could do it unless I had custom super deep rotor hats and very custom caliper mounts and then might not clear the suspension, etc...but I made it happen
These are only made in 4x100 but if you read my next post you will see what can be done for a very reasonable price.
I built the BBK, front and rear sets, to fit under 15x9 Konig wheels for my race tires and then bought more for summer only tires, it took considerable effort. I love the ride, performance, etc, so much on 15's I did not want to run the 17 Konig Feathers and Mich PS-3 AS tires, far to harsh. So I looked long and hard for a solution and with some templates and a lot of careful measurements I was able to determine the 6UL would be a very close fit and I could mod the caliper mounts a bit more if needed.
Nice little lip on these wheels
Great news, they fit, not quite so great, have to run 5mm spacers that I run with my summer tire setup caused by the tires having a thick rim protector on the inside edge where it seems an odd place to have it on a directional tire. On my 225 RA1 race tire on the same 15x9 Konig Helix I only have to run a 1mm spacer.
I will run the 5mm for now but when I get the time I will mod the caliper mounts to eliminate the spacer on the 15x8 wheels.
