Hey guys, I got some downtime today again from work so I decided to tackle the 2J RMM insert install.
I am going to break it down nice and short, as always, this DIY is just for instructional purposes only, please use at your own risk, if you don't feel confident, do take to a shop!
I have also attached some pictures of the install sequence. From start to finish, it took me 1 hour with a second set of hands.
Basic required tools: Lift (preferable)/Jack stands/Ramp, Basic Mechanic Tool Set, Breaker Bar, Rubber Mallet, Hammer, Wood Blocks, hand-saw, shop-press (preferable)
1. Get car on lift/stands, I used a lift because it was available to me, lifts are nice, so much easier on your back!!
2. Remove the stock RMM assembly, very straight forward, just un-do the 4 bolts and wiggle it out, 2 really long bolts and 2 smaller one on the black thingy
3. After you remove the stock RMM, on the larger oval end, there is 2 ways of removing the stock insert.
A) Cut the rubber inner part, pop it out, then carefully hammer out the insert (Hard)
B) Take the whole assembly, press it out with bearing press set on a shop press (Super Easy and Recommended), I used the shop press way to minimize any damage from striking the RMM with my ham fists.
4. Take the 2J RMM insert, MAKE SURE TO ALLIGN the forward arrow facing forward (towards the engine), carefully hammer into the RMM assembly with a rubber mallet, make sure the 2J insert is centered!
5. Re-install RMM assembly now with the 2J RMM insert back to its original position, a bit of anti-seize never hurts, carefully screw the bolts back in, make sure its aligned correctly.
6. Hand torque all the bolts snug tight, I just did it as tight as I can with a 3/8 wrench, you can torque it down, but be careful not to over torque.
7. Lower car down, fire it up, enjoy the "buzz"
10 miles drive review: Holy COW! wow, on a slop scale of 1-10, the stock RMM insert is a 2 or 3, with the 2J insert, the slop is like 9 or 10, NO SLOP! At ldle you feel a buzz, there is more buzz and NVH, but this is expected from a solid delrin insert!
No wheel hop, the whole drive assembly feels so......stiff yep it makes me want to drive like even more of an idiot!
Thanks for reading guys, if you have any specific questions, just ask me!
