I use a gear puller to get the wiper blades off., shady, check out Airjor13s post and my build thread for how we removed the OEM stuff. I got my heat shield out after I removed the 3 dp bolts.
DONT try to pull it out from the bottom. Pull it out from the top, through the shift cables, and where the battery was. This will save you a lot of time. Or drop the K-Member, and pull it out from the bottom.
non catted and yeah atp came with studs so i used those. but whoever is lead designer at atp should really have rethought o2 locations... manifold heat shield hits it...
Hi! Just a few pictures from my Milltek Downpipe install.
I let the battery on its place. I just removed the wiper cowl completely. Then I removed the Air Intake. There's enough space behind the engine to have a nice work.
After unbolting the lower heat shield, removing both O2 Sensors and opening the upper heat shield bolts i pulled the stock DP under the coolant hoses to the battery till the flex pipe is over the axle.
I'm going to be attempting this soon, but I wanted to know if I should wrap my catted 2J Racing downpipe with DEI Titanium wrap. I've wrapped plenty of headers from my Honda days, but dont know if it's ok to wrap cats much less the flex section of the downpipe as well.
Good question. I think the wrap is a good substitute for the heat shield which is being removed. Other wise perhaps I wouldn't worry. Don't know what others think.
