2015 Fiesta ST Project - Part out or save?
Huntsville, AL, USA
Hey everyone, hoping to get some opinions from the experts. I recently picked up a project ST and it's worse than expected. I'm trying to decide what to do with it from here. If I save it, the goal would just be to get it running and driving for a daily commuter.
It's a 2015 ST with 285k miles. The original owner supposedly drove all over the country with this car. The second owner put about 10k miles on it before the slave cylinder went out and he sold it instead of fixing. I picked it up for $1500 thinking I would just replace the slave cylinder myself and get it back on the road. Now that I've looked it over a bit more, it needs a lot of work. I've included pictures to show the condition.
This is my plan at the moment but not sure if it's the right route:
Interior:
Fair bit of rust inside the car on the floorboards. Nothing I can't sand and treat with a rust-preventative coating to get another 5 years out of the car (I live where there is no snow or salted roads).
Missing the carpet and several trim panels and door handles. I can pick these up from my local LKQ - they have an SE hatchback that I can steal the black carpets out of for this car. Might buy new, it looks like they can be had for about $300.
Exterior:
Missing the spoiler. I already bought a replacement, will install when weather permits. Several minor dents and scratches, biggest dent being on the back of the roof. Not causing any issues and I might be able to hammer it out from the inside if I drop the headliner.
Right side mirror is broken. I picked up a replacement from my local LKQ which I'll install when I do the spoiler.
Has old focus wheels on it but I have a set of steelies with new tires that I can put on. One of the tires is not holding air more than a couple days so they need to be replaced by something anyway.
Windshield is cracked all the way across.
Cowl is dry rotted and cracked but I have a replacement from one of my other FiSTs in much better shape that I can swap out.
Mechanical:
I know it's going to need a slave cylinder so I'll be dropping the trans.
Engine seems to run fine but I have no idea the service history or what shape the turbo is in... I do have a 12k mile OEM turbo from when I S280 swapped my low-mileage orange ST. I also have a 125k motor out of another 2015 that I could swap. This is my biggest question. The head on the 125k motor is junk, so I'm thinking about swapping the head/cams/buckets from the 285k motor onto the 125k motor, doing timing belt and water pump, and then putting that combo with the stock turbo back in this car. That would be a lot of work and I'm not sure it's worth it for this shell. It might be better to save the 125k motor for another project and just fix the trans in this car and send it.
That brings me to my question (thank you so much for reading this if you got here)... should I pull all the usable parts from this car, including things like the engine, trans, lights, seats etc and either use them for another project or sell them... or do I use my extra motor and turbo, fix this car, and drive it until the rust claims it or the car dies?
Front Royal
I saw the post on the fiesta page. I would have bought it if you hadn’t.
if it were me, I would check underneath for rust. If it’s solid, I would do the clutch and see how it is and go from there.
GeorgiaFiesta
Huntsville, AL, USA
Ha yeah the fb page is where I found it. I'll get it up on jackstands next weekend and check the rust condition. You're probably right, if I do the slave and check out the clutch, I'll know if it's worth it to keep. For now, the interior fixes are cheap and easy so I'll take care of them either way.
Suwanee
its not a sunroof car, so it's probably worth saving, assuming the rust isn't terminal. 285k is a lot on a car, and the fact that thing isn't worse would be a sign of hope to me. probably a nice find to either mod or flip.
GeorgiaFiesta
Huntsville, AL, USA
Well guys... looking for advice on this one. I pulled the motor and trans from my high mileage (287k) ST so I could replace the clutch slave cylinder and swap the motor for a 125k mile engine out of a 2015 ST which I found on FB marketplace.
The guy I bought the motor from said it was pulled because he cross-threaded the spark plug for cylinder 3 and even though he tried using a helicoil, it wasn't holding compression. I took his word that the engine ran fine otherwise, and didn't borescope the cylinders (foreshadowing) - just paid the $600 for the motor and drove from Alabama to North Carolina and back to pick it up (5 hours each way).
Well today I was pulling the cylinder head off the donor motor and found catastrophic piston damage in cylinder 3. I think the previous owner likely knew and lied about why he pulled the engine from his ST. This, I'm sure, would have caused the motor to run terribly, if at all. I'm posting to get y'alls confirmation that this can't be fixed with a new piston and a re-sleeve of the cylinder (is this even possible?) and that this donor motor is effectively a paper weight. Thanks for reading!
Suwanee
Ouch. It's likely possible to resleeve, but a 1.6 block from an escape would be a lot less fuss in my opinion. That's really lousy and I'm sorry that happened.
GeorgiaFiesta
Huntsville, AL, USA
I pulled the piston today. I have no idea how this could have happened, but it's back to the drawing board for a donor motor. Donor Motor Meltdown.JPG
Burlington, NC, USA
I pulled the piston today. I have no idea how this could have happened, but it's back to the drawing board for a donor motor. View attachment 65046
How much did you pay for this? I’d at least threaten civil litigation to see if you can recoup some money depending on what y’all’s conversation was like.
GeorgiaFiesta
Huntsville, AL, USA
Hey everyone, I'm pretty exhausted with trying to get this car back on the road. I fixed the trans and put the old motor back in the car together, with some new parts like a fresh turbo/downpipe off another of my STs. Thought I was done, but I can't get the car to start. It will crank all day long but it won't fire.
Here's what I've checked so far:
  • Low pressure fuel pump is working
  • Under-hood fuses are good
  • Battery is good
  • Motor is grounded
  • All wiring harness connectors are plugged in
  • Replaced cam position sensor
  • Replaced spark plugs
  • Replaced coils
  • Finally this morning I checked the coils with a Lisle coil tester and it looks like they are NOT getting power
  • Have a crank position sensor and VVT solenoids ready to install but stopped after I tested the coils
I'm not sure why the car's ignition system is not sending spark. The motor ran just fine before I pulled it. Stupidly cleared the codes when I pulled the motor and there are no codes present still.
I think my next step is to pay a mobile mechanic to come over and plug in a diagnostic tool and see if they have any idea why it's not sparking off.
Have you guys run into this? Any ideas why the coils might not be getting power? I'm at a loss. Thank you immensely if you read this!
Suwanee
do you have a wiring diagram? what you're describing sounds like either a fuse blown, or you missed a plug somewhere. actually, now that i'm thinking of it, is there an anti theft on these cars?
