I can't seem to get the suspension bolts loose to install the front, 2 point brace. I have the car on ramps with a 15" socket wrench, 18mm socket, attempting to turn counter-clockwise.
You ABSOLUTALY need to have the suspension un-loaded.
You will NEVER get the bolts out without unloading it.
If you were to get a bolt out the suspension will collapse, so PLEASE don't be under it.
A 24 inch breaker bar works best but you can put a length of pipe over your ratchet.
I also would only recommend 1/2 inch drive.
If you were to get a blot out the suspension will collapse, so PLEASE don't be under it.
Thanks Dave. Great ideas and thanks for the heads up
As mentioned, the bolts will only be loosened by a few mm's, not taken out. This is a very exciting and new product that is installed without removing the bolts at all.
Good advice. I sprayed and put a gob and a half of strength, but I didn't have enough leverage lying on the floor under my car. Next step is taking it to my local shop on the lift, lame.
This is not a Pierce part but a part from another reputable vendor.
Sorry for the wait. Will certainly start a new thread once I bring it in and get installed.
