I had mentioned a week ago that I was going on a road trip with these new tires. I thought I'd give some feedback on these R888's.
In 8 days, I covered 3,970 miles in the West. Much of it was in canyon type driving where I completely bottomed the suspension in every way possible. They are the best DOT street tires I've ever run. They have tremendous grip and are very communicative with lots of warning near the limits. Even after running them hard on this trip, I still have over 2/3 of the tread left. In rain, I think they are no worse than max performance street tires such as my AD08R's.
Several times on this trip, I got the tires fully up to temp where the tread is melting and abrading off like a gum-rubber eraser. The grip is exponentially better than my Advan AD08R's.
They grip so hard, that I'm being rolled out of my Recaro's upper seat bolsters. My thoughts of needing a LSD went away with this level of grip. Even in 10mph turns, no wheel spin. They also behave like a street tire in that their minimum performance temp is 160 degrees. Unlike other DOT R tires that need lots of heat to keep them from sliding, these get up to temp within minutes of normal street driving. Drive them for 5 minutes and you're ready to go! At those temps, you have incredible grip and you're not cycling the tires.
The 50 series sidewalls were a concern initially for turn-in response. There is no wait for the sidewalls to roll-over and take a set despite being on 8" wide rims (which incidentally is Toyo's recommended width). Turn-in response is instantaneous. There is no squirming of slip angles. By the time you're doing a 5-7 degree slip angle, this thing is probably pulling 1.4 g's on this car with stock springs and bars. And, it's incredibly neutral at 36/34 hot.
This car was made for these tires. I hope someone will get wheels in the offsets I've mentioned to enjoy what I experienced.
Oh, btw I installed the DIY brake cooling ducts from a post on the other forum just before this road trip. Last year on these same roads, I had fade with R4 pads and Torque fluid. This year, stock pads and Torque fluid had no fade. This would work on the track too. Stock pads don't have as much braking torque, but they don't chew rotors. I think it's a good balance for a road car and occasional HPDE days.
