SLD 02 SVT Focus 164k miles 1 of 400
Trader history for Fk8_FiST386 (0)
Medford, OR, USA
Delete if not allowed
2002 Ford SVT Focus
1 of 400 made in this year/color combo
-SVT Cosworth engine
-164k miles
-Windows recently tinted 15% all around new
-CJP Ford Racing GT40 style shift knob new
-New SP-463 spark plugs new
-Hella Sharptone horns 10k miles
-Oil just changed with Mobil 1 5w-30 high mileage full synthetic oil
-Voltex shorty 6 3/4” car wash proof antenna
-Fresh coolant flush with Ford OE coolant
-Winter package with engine block heater, defrost mirrors, and a rear defrost window
-New Kenwood Bluetooth deck with hands free and sub, can include sub for extra. Amp not included.
-K&N panel filter(2 to change back and forth between changes)
-Timing belt done at 130k
-OE hydraulic passenger engine mount and drivers engine mount 10k miles
-New water pump recently
-New clutch master recently
-Ford contour revised t stat housing, thermostat, and temp sensor 10k miles
-Massive Motorsports race dogbone mount 10k miles
-New IMRC(intake manifold runner controller)
-Ceramic pads and new rotors front and rear done 10k miles
-Massive Motorsports adjustable front sway bar endlinks 5k miles
-Ford Racing struts 10k miles
-H&R race springs 5k miles
-Energy Suspension poly adjustable rear swaybar endlinks 5k miles
-Poly swaybar bushings 5k miles
-FSWerks race and stealth exhaust 5k miles on race section and not even 1k miles on stealth section
-UK ORP titanium heat wrapped with new upstream and downstream o2 sensors
-Battery done almost 2 years ago and tests strong still and alternator done end of last summer
-Serpentine belt, idler, and tensioner 10k miles
-Newer tires all around
-Oil changed every 2500 miles
-Led headlights, fog lights, and dome lights.
Clean title in hand
Front of car has some damage from a minor fender bender.
Have a euro hood to go on and could use a passenger headlight housing. Paint the hood, bumper, and blend the fenders. Or just drive it like I’ve been.
Comes with stock exhaust, stock cat, and a few other bits and pieces.
Needs a valve cover gasket. Doesn’t leak bad, but you can smell it once in awhile.
Needs tags but passes DEQ, just haven’t had time to take it with work and it always being busy. Bring a scanner if you want and see for yourself.
Nothing wrong with car besides cosmetics, selling because I got my FiST.
Would like it to go to an enthusiast or someone that’s gonna appreciate it.
$4800
Located in Medford OR
