Lemon's X47 track ST
lemonjs
United Kingdom
Thread Starter #121
I've begun the next stage in the weight loss. I decided that I'm going to remove the AC and fit a small race heater for de-misting to supplement the heated front screen (which I'm shocked you don't get on the US cars).
I've ordered this AC delete pulley from SiCo Developments, and will soon pick up this heater. I'll run some ducting to the two outer vents and point them to the front windows.
I removed the stock fan assembly today in preparation for all the other stuff. In order to remove this properly, it looks like you'd need to move the cross beam out, so I ended up settling for the destructive method. I then cut out all of the framing that was no longer needed.
Once the AC delete pulley arrives I will remove the radiator, and weld in some plates to block up the holes. At some point this year I will pull the loom and de-pin everything that's no longer needed.
lemonjs
United Kingdom
Thread Starter #122
The AC is fully removed now, and I added a small carbon fibre panel to put switches in. It's not pretty, but good enough for a track car. I still haven't decided what race heater to go for. I've narrowed it down to either a 3.5kw (here) or 5kw (here) unit. Its only job will be to make it bearable in the winter, and to de-mist the door windows.
lemonjs
United Kingdom
Thread Starter #123
Spent some more time removing excess wiring and tidying up the mess I've made over the last few years. My goal is 999kg, which I think will be doable once the rear windows have been replaced with plastic, and potentially a lightweight race battery.
I removed quite a lot this time, fortunately everything that's still in the car works:
Here's what it looked like before:
And after:
And the final weight is 1040kg:
lemonjs
United Kingdom
Thread Starter #124
Plastic windows are in at the rear now too. I really did try and remove the old windows gently, but in the end had to resort to destruction.
Glued in:
And done:
I started with the side windows and make an absolute mess. I'll need to try and find a way of removing the excess adhesive. The rear turned out pretty good once I'd got some practice. I weighed the remains and it came to around 20kg, so I should be around 1020kg total now.
Also, ordered some new driveshafts fgrom Ford which I'll install this week:
