Hey everyone. I am looking for the rear passenger side. Is this the correct color for the FiST? Thanks for the help. There are a lot of references but I am not sure if this is correct.
I wasn’t hitting targeted boost numbers (still low due to tuning) until 4600 and it wasn’t stable. I knew it leaked a bit but didn’t realize how bad it was.
Installed the worfab manifold, which fixed the leak. I’m hitting targeted boost now 1200 rpms earlier.
I was pulling into work the other night and heard a very loud/felt a hard clunk from the front right tire. Turns out I destroyed my strut mount. Luckily Napa had it in stock for the oh so totally reasonable price of $80. Took about 45 minutes and we're good as new.
Installed Dizzy's V3 tune, replacing the E30 tune. Very smooth. Loved the E30 tune, but I have to go out of my way to get E85 and my track days are over, so the V3 is going to be a lot more convenient.
Thanks homie. Fortunately it was two miles from home so AAA got me and it was a cheap repair! I still need your Forscan assistance for that camera but I've been slacking on finishing wiring it up.
First time doing an oil change after installing the Fumoto oil drain valve. I should've installed it from the get go since I don't have to worry about the oil stream hitting the brace or having to align the drain pan just right.
I looked that up and found this bit of advice: N-Series valve (with nipple to accept hose) is not recommended for passenger cars with low clearance. Is that of any concern if I've lowered my FiST?
