TS IWG on S 280
Namibia
Hi ... Can someone please confirm if this part number turbo smart waste gate will be a straight fit on my S280 and any how to fit links available ...I've already removed the turbo
ron@whoosh
Vendor
Las Vegas
you're wasting your time with a 10psi WGA as the supplied S280 WGA is 7-9psi
additionally, the S280 WGA we supply in the USA is custom made by TS for the S280, it is not an off the shelf part
Burlington, NC, USA
Just confirming Ron’s post above. It is indeed a TS IWG75 in the kit labeled as S280-specific. Measured the rod and it is not 150mm so yours would require some modification to work with the S280 I assume.
T
Namibia
Hi
HI Ron ... My Tuner asked me to get a 10 psi spring .. with regards to the actuator .. i ordered S 280 specific from a certain company and they supplied me this one ...
