I'd say it's worth it if you are running out of other weight-loss ideas. Swap was easy and the CF hood is much lighter. I don't have a way to measure the hood weights but it's about 10 lbs lighter per the
Fiesta ST Weights Thread. I added a couple of washer for the rear to line up, but otherwise, the fitment is good. Rubber piece you see in front is due to the bumper cover bulge from the aftermarket IC install and was there before the hood swap.
Their CF hatch, on the other hand, doesn't fit was well. It's hard to tell in this picture, but the gap on the left side is about double the right side. But I guess making a hatch is more complicated than a hood.
