Lemon's X47 track ST
lemonjs
United Kingdom
Thread Starter #101
Most on here would know Goodwood for their annual Festival Of Speed held there in late June or early July, with all of the recent, vintage, and historic race and rally machinery run there (and on the hillclimb as well).
I would love to do the hill climb but I don’t think it’s open to the public!
lemonjs
United Kingdom
Thread Starter #102
Just picked up a Coolerworx shifter for £433 including taxes and shipping. They have 30% off for Black Friday and couldn't resist.
lemonjs
United Kingdom
Thread Starter #103
Installed the Coolerworx shifter today, and not one part of the installation was enjoyable! I used the video from Spark Plug Steve as reference, but it seems they have revised the design since his video came out. You have to wrestle the shifter cables into place, and there's barely enough room to fit a spanner inside the frame to tighten everything.
However, it is in now, and it feels absolutely incredible!
My previous set up was the stock shifter on stilts. This worked surprisingly well and I'd recommend anyone to do it if you don't have the centre console. I also had a Pumaspeed short shifter which I removed.
They supply a new linkage for the shifter cable and you need to cut the old fitting off. The new fitting is held in with grub screws, but I think I will add a small blob of weld next time I'm at the garage to ensure this doesn't pop off.
All installed:
I spent about 20 minutes adjusting the screws to set the end of travel for each gear. Everything feels so crisp and sharp, it's quite incredible!
lemonjs
United Kingdom
Thread Starter #104
Today I fitted some polycarbonate windows from ACW motorsports. They're 4mm thick and have sliders with a locking mechanism.
First step was to gut the doors. It took quite a while to figure out the first one. There's quite a few videos on YouTube for the US 5 door, but the UK 3 door is totally different and I couldn't find anything. There's little clips that you need to free to release the window instead of a 10mm bolt. I couldn't see any way of the inner skin and the mechanism going back in once it came out - good job they don't need to!
Next was to test fit the window:
I used some long M6 bolts with a some nuts and washers to push the window as best I could up against the weather strip. I think I'm going to run some sealant over it as I don't think it's going to be enough. At least they are locked in place with these:
And installed:
At the weekend I will strip all the excess wiring out of the doors and find some way of making some door cars. I'll also probably replace the rear windows and the boot/trunk window at some point too. I didn't weigh anything, but the glass window setup was significantly heavier!
lemonjs
United Kingdom
Thread Starter #105
Small update. I de-pinnined and removed all of the wiring that was no longer needed in the door, and create a temporary solution for the door handle.
I was hoping that I could remove the Door Control Unit altogether, but my guess is that it's listening to a CAN signal and managing the door locking functions that way. In which case, it would need to stay as I still want the locks to work. Hopefully someone here knows how it works!
I'll order some door cars from http://trackcardoorcards.co.uk at some point as it looks a bit ugly right now.
On a side note, I took the car for a drive last night and the outside temperature was -4c (24f) - not the wisest move with no heating and plastic windows.
lemonjs
United Kingdom
Thread Starter #106
Continuing the quest of reducing weight, I removed all of the sound deadening in the car.
I went with the heat gun and scraper approach and found it to be quite easy for the most part, even with outside temps being -2c (28f). The only difficulty was with the stuff inside the doors - the material and adhesive was different to the floors and would only come off when it was not too hot, and not too cold.
The total savings was 8kg (17lbs). More than I thought it would be, but also way more effort than I thought.
It all came off in pretty big chunks:
And all back together:
lemonjs
United Kingdom
Thread Starter #109
I’ll have a look and see if I can find an M-Sport dash for sale. Even with most of the dash cut away it’s still quite heavy.
It’s been playing on my mind to remove the AC, and maybe even the entire blower setup. I’m sure I’ll regret it, but I rarely need it.
Woods247
Atl
Having removed it from my other car I definitely regretted it. I actually reconnected the heater so I had the defroster and a warm cabin again. I don’t miss the AC since it’s a track car but not having a way to completely and easily remove fog from my windshield on wet days sucked
lemonjs
United Kingdom
Thread Starter #111
I currently have the opposite set up, no heating but still have AC! I’m looking into using NACA ducts on the rear windows, or fitting a lightweight heater (something like this). Either way, I’ll be removing the AC, but still want some way to remove the fog.
Woods247
Atl
That looks promising. I know a few guys that use cheap 12v heaters from Amazon and they’re awful.
Atl
I wonder if something like this would work for you guys, easy to wire, lighter/simpler than a heater core.
@Woods247 @lemonjs
I’ve been in cars with that and I personally didn’t like the obstructed view. I guess I’d get used to it but I’d rather not have tired eyes accidentally focus on lines instead of the track. I’m one of the weirdos that always has coated clean windshields though.
Nope.
We have the defroster vents only as a means to defrost/demist our windscreens.
Ironically, since many parts here (and even more so the 'north country' where Volumetrik is), get MUCH colder temps, and much more frozen precipitation than you will ever get in any of the even northernmost British Isles.
But then most here would balk, violently, at the co$t of replacing said heated windshield if they ever needed to do so.
Montreal
My windshield is currently cracked and looking to replace it this spring, that's why I was looking at this. Only thing is, will my insurance cover an externally purchased component? Furthermore, It's unclear if it's quiet like the SoundScreen acoustically laminated OEM glass panel.
lemonjs
United Kingdom
Thread Starter #119
Just got back from a VERY wet day at Brands Hatch. It rained non-stop all morning, and there were so few people out that the track didn't dry out even after the rain stopped.
It's always a gamble doing a track day in the middle of winter, but it was still fun nonetheless.
On the last two track days I've had a weird clicking noise from what sounds like the front wheel area. It's rotational, and not related to the brakes. It only happens once the car is super hot, and the noise goes away once it's cooled down. I might pull one of the driveshafts and inspect for any wear. My driveshafts are 12 years old and have had almost 2x the intended power put through them, so I won't be mad if they're on their way out. If anyone's had something similar, please shout!
