My cents/sense.
#1 and I really need everyone to keep this in mind... Like the cyborg turbo or hate it, its a different animal than the stock turbo. I was very surprised in how much the car needed tuned for it, because it is a good size change. But this is an intake review, not a shameless plug, lol. But I wanted to make it clear that everyone maybe not find what I have, being the difference in turbo.
Fitment, and what's included:
I like what's in the box. Filter is small, but who are we kidding, we knew it was gonna be small, look in the space it fits in (its not a choice ). Clamps..... What clamps? Didn't come with hose clamps. I had to reuse the stock hose clamps from my stock intake. Hose clamps are cheap. And the cheapest ones would have been extremely effective, because..... It fits fantastic !!! Not everyone knows what it takes to fab something like this, and even looking at it, it doesn't look very special. It is. The space it has to deal with, and the angles and size of the tubes, means it has to be right. And.... Mine was def right. Now.... During install, you may think "mine is not right, it can't be this tight", while your trying to get it in. I thought that, lol. Once its on, and you see how well it fits, and has room for adjustment ( my personal cyborg intake was tilted a few degrees backwards on purpose when it was built with the idea that I was going to be fabbing an intake like this some day ). It adjusted beautifully, and I'm sure it will fit a stock intake even better. The fittings and hoses that came with it are spot on. Perfect sizing. My one tiny little gripe that I'm likely wrong about is... The big hose for the valve cover breather, it pulls vacuum. For a hose the pulls vacuum, it folds in very easily. Not sure it wouldn't cave in when vacuum is applied. But... How much valve it sees? I don't know... I'm not gonna lose sleep over it. The fittings welded to the pipe seem more than upto the task, and they are sturdy. The maf adaptor didn't look like the threads in it that hold the sensor in ( torx screws ) were the correct thread. Maybe they were.... Either way, I threaded them in and felt good and tight, and secure, no worries there either.
I am extremely happy with fitment. It beat my expectations, honestly.
Sights and SOUNDS.
Its fucking loud. It is. Its loud. Joe told me it was loud 10 months ago. I told you guys it was gonna be loud. Its loud. I have a loud catback and a catless downpipe. Its louder. Its loud. Its nearly silent at idle ( remember, I don't have a stock turbo ). Drive slow, maybe flip an eco mod on and it could be just a little loud. Drive the way I drive ? Its loud. The cyborg spools with much more "control" vs a stock turbo. Mine is loud. It goes from being one of those little jet engine powered bikes to full on Atlanta airport run way loud if I matte the throttle open. It screams. Oddly, once the turbo is making 25-26psi, it quiets down ( but its loud ). My car already made BOV sounds. Just a side effect of the cyborg and large inlet. But now.... Its full on Greddy BOV on a 2nd gen DSM loud, lol.
Performance:
I thought the new intake would be a game charger for the cyborg. I have not looked at the logs, and its so hot outside right now, i'm cooling off typing this before I look into the datalogs. That being said... Its had the exact effect I had hoped it would on the spool and boost of the cyborg. The car has increased 1-1.5psi peak boost with no changes in tune. Without seeing the logs.. I can't speak for much else "apples to apples". But generally, when its 86 degrees outside like right now, I see about 25.5-26psi. I saw 27.5~psi with no tune change at all. The difference this makes across the powerband is yet to be seen and cooler weather it required for my logs to be comparable ( give me a couple days, but I will have some data tonight as well ). Ok... Here is the thing... Just like a bone stock exhaust, swapped for a catless big exhaust system, you have to think and believe that you gained something. Did you ? Hard to say.... Why is it hard to really say? The sounds the car makes just completely changed, and if you think your butt dyno can compensate for this level of DB sound level change, your wrong. It can't. Only logs and V-dynos, and real dyno's will truely tell us. Same is true for me. Sorry, but this is a "stay tuned" paragraph
initial results.... Yea.... Its gonna be a game changer for the cybrog at least. Just realize... When you guys are at 6000rpm and 14psi, I'm at 6,000rpm and 27psi. So.... My air feed requirements in the upper rpms are much different. Which is why I was so excited over this. I hope it translates to the stock turbo, and i believe it will, but maybe on a lesser scale.
$162 shipped? Worth it every single day of the hour !!! Lol.
