Thanks guys... don't get me wrong - I think they look awesome. The reason I want 16's is simply I want lighter weight wheels. Probably will just get assetto gara's (sparco).
Also, they would look wayyyy better in a proper offset (+40 or 42).
Summit Racing has them on ebay for $600 shipped, pretty good deal to me. I'm going to pull the trigger soon just can't decide on silver or black.......also wondering if hub centric rings are required??
If they list the hub bore as 63.3 then no you need no hub rings as that is the size bore we need.. ask before buying if it is not listed just to be safe . A bigger bore is not problem but too small a bore and you will need to get the wheels milled to fit..
I would GUESS they will be fine as they are FORD wheels and should fit.. but to be safe ask...
Got it. Thanks. I don't think you need any rings. Especially if they are the same ones from tirerack. I just wish they stuck out more. Giving a more flushed look against the fenders. That's why I'm leaning toward the sparcos.
