Any tips on adjusting an exhaust post-install? Jacking it back up tomorrow to fix the vibration of my Injen cat-back, it's literally sitting on top of the frame brace in the middle of the underside, I'm not quite sure how to adjust it as this is the first exhaust I've ever swapped out, I have the Cobb hangers and it's almost as if the flange where the cat-back connects to the downpipe is too long or at too much of an angle and is making it sit right on top of the frame brace. For what it's worth I installed both my Mountune downpipe and Injen exhaust last weekend. It doesn't look like there is any play at all with the downpipe as it's fairly well bolted down but I should be able to adjust the cat-back piping.
I imagine since it's been on for a few days and a couple hundred miles that it should be nice and settled now, should I just unbolt everything and try to push the middle pipe as far up (towards the top of the car) as I can before bolting everything again?
Ehh it's all good, while true they should not advertise it as a full 3" from tip to tip, a lot of other manufacturers do this too. Anyway, it sounds great!
