Thread Starter
#61
You keep talking about 215/40/17. 205/45/17 gives you as much overall diameter as 205/50/16 (your 16" option)...and there are many tire options at 205/45/17. 205/45 fills the stock fender gap nicely. Use a tire size calculator to play with overall dimensions. I will tell you that after having this wheel setup - I want to get lightweight 16's like I originally wanted due to less weight and more sidewall. I will tell you the car DOES ride better at 205/45 than 205/40. However, the increased diameter while maintaining same weight wheel gives the car a bit of acceleration lag in 1st gear.
Here is my car with stock suspension, 205/45/17 tires on svt wheels. Oh, I also wish I had a lower offset like aftermarket wheels (+42)
![](http://www.fiestastforum.com/gallery/data/505/medium/20141026_1744431.jpg)
