You see where that shroud is that gets cut for the big mouth? The bumper sits over that and creates a pocket where the intake draws in outside air. Just to the right of that from this picture on the curve of the shroud is the ambient air temp sensor. It pokes through the bottom side of the shroud and gives you your air temp you see in the center of the gauge cluster. It gets hot in that plenum. Really hot. So, que the big mouth to bring in ambient air. Now, I have not personally compared ambient, intake, and charge air difference but I can tell you my black Whoosh intercooler sits at 5*F when driving, maybe a little warmer if the sun hits it on the drive, and 100+ when sitting in traffic.
Now, with the big mouth, you will get a little water in the air box if you're driving in the rain. I kept the stock air box to let the water fall out of the air and get as far away from the filter as possible, until I got the Cobb intake. Play it safe and you should be fine. You will get bugs in the air box and more dirt. Just clean and recharge the filter every 5k miles or so.
I noticed better throttle response with my big mouth when I was stock. I upgraded intake and charge pipes and diverter for future expansion and sound. Velossa Tech shows a 5hp/Tq gain as you're flowing about 5lb/min more air per their test and data logs. However, your mileage may vary. I don't think I've seen a set of independent logs though to back up or dispute VT's gains.
I'd say go for it. Big mouth, panel filter, and rmm on stock turbo with a tune and you're golden.
Just my two cents.
