CLOSED: Cyborg TurboCharger * NOT AVAILABLE *
Status
Not open for further replies.
Sourskittle
Sourskittle
Lakeland
Thread Starter #1,062
SS, I thought you cracked your head on your lunch break? You said you didn't wait for the engine to warm up before you dropped the hammer on it?
That's honestly what I thought. And I was willing to accept that. Until the second motor I took a part had the SAME EXACT CRACK, IN THE SAME EXACT place. Then I found out ford recalled 140,000 1.6L turbo engines for this. There fix was...... A software update.
frankiefiesta
forked river
Well frankiefiesta how is it so far?
Had a few issues with other things, not the turbo itself. Car was having trouble keeping a consistent afr
Downpipe bolts apparently came loose on the ride to the shop (exhaust leak = the funky afr). They are going to retap threads and put some new hardware on. Turbosmart shortie BOV is leaking or not working correctly. The shop was going to take it apart to inspect and give me a call Monday. Then they are going to retune the car for me.
Sourskittle
Sourskittle
Lakeland
Thread Starter #1,070
Thaaaat is a thing of beauty.
It actually wasn't fulling tuned. That was with the meth pushing the AFR into the 9.8 range still in the mid-range and the AFR on the upper end was still rich too.
I was waiting on the ATP intercooler to finish tuning it ( and for some more fuel help from DHM ). But the whole cylinder head thing came up... I just need time to work on the car now...
Sourskittle
Sourskittle
Lakeland
Thread Starter #1,072
Mr. Sour,
You sure you don't want me to tune that hog?
Cyborg, EWG, Full Bolt Ons, Stock Fuel System, No Meth, E40.
Great job Adam !! 26psi to redline? I LIKE IT !!!
Who's car is it?
I was thinking today.... Since our coolant temps rise so fast, and the car does loose power because of it, I wonder if any of the guys going to upgraded rad will see power rise....? Random thought.
I had no doubts you could tune the fuel Adam :)
Lewisville
Who's car is it?
You only lose power because timing is reduced. Timing is only reduced if you allow timing to be reduced if you are picking up what I'm putting down.
I also make changes to all cooling tables, not a single one goes untouched.
Campbell
Sourskittle, you should do it just so you have a target to shoot for with your tunes.
If Adam does a really good job, you will sell more Cyborgs too.
Lewisville
What does this translate to power wise?
FUN.0whp and 3rdGearBurnouts.50wtq.
:-D
Honestly, not sure. I would actually need to get some more data from the car to get a better idea. Obviously I would recommend the customer getting on the dyno to get some numbers rather than guessing.
260-270whp - Shot in the dark.
Campbell
Without any scales on the axis, it is hard to tell what it means, what is the RPM where AFR and engine speed cross?
Miami
:-D
Oh yea! This is great news, I will definitely try to get E30 soon for my EWG cyborg as well. Still need to order the 2J though....
Status
