Cyborg upgraded stock Turbocharger system
fantastic...so my car is going to burn to the ground...
No... Of course not.... Ford updated the software, so no way your poorly cast cylinder head will crack now, lmao.
Watch... All the ecoboost F-150's that are suddenly having brake failures now, will be fixed with a "reflash of the vehicle manager", lol.
So... What the problem? 161,00 1.6L engines will built likely will be cracking cylinder heads due to "localized over heating" that the operator can not see or prevent.
So what are we going to do to fix the cylinder head issue ?
#1 change the motor we use in the fusion so it doesn't suffer the issue anymore and get its ass kicked by the Camery more than it already is..
#2 the remaining engines we already have built, install those into a group of care not likely to have any warranty recourse do to mods.
#3 the 161,000 escapes we already have out there nearly burning people to death due to poorly cast or poorly designed cylinder heads, ummmm.... Update there tune and change the heat shield so the oil runs off the engine and under the car; not onto the turbo. That should stop the head from cracking !!!
The same team that worked on the focus DSG and powerstroke 6.0L diesel figured that fix out.
