Entire Cyborg turbocharger system. $1450 + $400 refunded core (optional so you'll have zero down time ).
Cyborg Turbocharger System includes:
Upgraded from stock Borg-Warner KP39 Turbocharger modified with a much larger billet aluminum compressor wheel, all new seals and bearings, and a custom optimized turbine wheel clip. (We do not publish or share compressor wheel specs or turbine clip measurements ).
Big polished Stainless 2.5" inlet tube that is hand made in the USA.
Fully ported and polished exhaust manifold.
*( keep in mind that ATP turbo kits use the stock manifolds, if your going that route, I can do a core charge with these as well and you'll have zero down time for your big turbo install as well as extremely improved flow for the new turbo (PM for pricing))
Full port and polished exhaust turbine housing.
>We remove the wastegate arm and port all the way through the wastegate path as well as port as deep into the turbine housing as you'd want to port.
Upgraded/Modified medium EFR internal wastegate
*(PM if your interested in converting to an external wastegate on the manifold ).
Very detailed and imagine heavy info can be found here on the forum.
http://www.fiestastforum.com/forum/showpost.php?p=43109
PM for any question or post if you'd like
Flat power band that doesn't ever fall off.
Ok, so this picture is my actual turbo that was recently installed and it's perfect! I'm still figuring the data log thing out (I had the Livernois tuner) but at a glance of the Cobb AP I was holding in my hand I saw 21psi at 6000rpms going on the on ramp before coming up on traffic. It should have come from the factory like this! I didn't leave the dump pipe to atmosphere, I had it re-routed to the downpipe to keep it visually legal at tech inspection, can't see anything from below. I also still have the factory intake (still waiting for my 2JR cowl one) with drop in filter, CP-E catted downpipe and exhaust (love the no drone and sound) and a large FMIC and racebar. I installed a Quaife LSD at the same time and this is definitely needed with this power. I actually thought it was slower or not much power because I usually have wheel spin in 1st, 2nd and 3rd with a little torque steer pull but nothing, this thing just pulls hard from about 2700 to 6500... NO regrets...
I sent a half-assed data log (like I said, still figuring this thing out!) and the tune the local tuner did to sourskittle and he told me I have a lot left in it. With him having said that I'm emailing Adam (at MaPerformance) the tune and let him do his magic!!
I've done the big turbo, small displacement before and HATED the turbo lag so much I got rid of that car (back then), this might not hit 350-375whp (like the big turbo guys are getting) but I haven't lost ANY low end power feel that I loved about the FiST!! Stay tuned as I post more info...
