Here's my write up on my home depot husky oil catch can.
Shout outs to westcoaST, Dave, and lessard.dcj for posting pics of their setup, so my first attempt wasn't a total disaster. I copied a lot of different member's ideas with this setup.
Parts:
Husky Catch Can: $23 http://www.homedepot.com/p/Husky-3-8-in-Standard-Poly-Bowl-Filter-HDA70603AV/100040942 (Sidenote Ford actually used this exact part as a catch can on their GT500 test vehicle http://www.camaro5.com/forums/showthread.php?t=199357 )
90 degree 3/8 NPT to 5/8 Barb $6.75: http://www.amazon.com/gp/product/B008TT2P6G/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 (I have 8 extra )
5/8 to 5/8 brass hose barb $6
90 degree 5/8 to 5/8 barb (from garage)
5x hose clamps (from garage)
Lucky metal bracket find in garage
Extra PCV hose from Rock Auto $24.95 (inc shipping) http://www.rockauto.com/catalog/raframecatalog.php?carcode=3298497&parttype=11784
Power steering fluid hose: $10
Something like $66, but more like $80-85 if you count buying the junk i already had in my garage
I'll start with what I'm least happy with, and would probably change.
#1 I'm not sure about the durability of the polypropylene 90 degree hose adapters on the can. They are rated like -20 to 150 degrees which may not be sufficient (PSI rating is fine and they are fine with oil/gas). I'm sure Brass would be better, or even nylon.
#2 the power steering hose, it's pretty thick, and re-enforced with fabric on the inside, but it's definitely not stiff enough to handle the vacuum when you're off throttle. It compresses down, although it doesn't totally choke off the flow, I wish I got something that was much stiffer. Under boost it's fine, I think it's rated for like 200 PSI.
The husky catch is really nice, it's baffled and filtered and rated for like 150 PSI.
I had to put jbweld over the valve on the bottom. The valve is super slick if you have it hooked up to an air compressor. When the canister is NOT pressurized, the valve is always open (regardless of which way the valve is turned). But in this application, it's worthless, and oil would leak all over my engine bay, and it would pull in air when under vacuum, so I sealed up the bottom valve with jbweld.
I cut the OEM hose, but getting it on the 5/8 barb is tricky, I had to put the hose in boiling water to get it to go on (no hose clamp required here!)
Mounting to the engine bay I got pretty lucky. I found a metal bracket that was used for mounting trailer wiring and it fit pretty good (after a bit of filing)
I drilled out holes in the bracket to get it to fit, I think I can trim the bracket down so it fits better, I'll probably do that if I switch out the hoses for something stiffer.
Here's what it looks like, with all the hoses routed and with it mounted. My biggest gripe with the mounting is that random stud sticking out of the shock tower. It is RIGHT in the way of where I want my OCC to hang. I haven't brought myself to breaking it off, but I'm close
Oh and the engine cover goes on just fine, it's pretty stealthy looking with the engine cover on. I'll probably trim up the hose clamps at some point too.
Parts:
