Starting this thread as an outpost for technical data on the avail intercoolers.
I will update as new info/products are offered.
The core dimensions are taken by the posted manufacturer specs. If you own one of these and find the measurements in the real world are different, please let me know!
One thing to note is that size isn't everything. Core design itself makes a performance difference.
Items with a ** after their name are not true bolt ons and require fabrication.
Stock FiST IC
Core Dimensions:
27.5" x 5.25" x 2"
Approx. 5lbs
Core Volume:
288.75 in
The list is in order of Core Volume.
Mishimoto J-Line IC**
Core Dimensions:
22" x 7.2" x 3.75"
Approx. 19lbs
Core Volume:
594 in
69.1589% difference over OEM FiST IC
18.1818% difference over Cobb IC
Cobb IC
Core Dimensions:
27.5" x 6" x 3"
Approx. 13lbs
Core Volume:
495 in
52.6316% difference over OEM FiST IC
5.6075% difference over ATP IC
ATP IC
Core Dimensions:
24" x 6.5" x 3"
Core Volume:
468 in
47.3736% difference over OEM FiST IC
1.2903% difference over AIRTEC IC
AIRTEC IC
Core Dimensions:
28" x 6" x 2.75"
Core Volume:
462 in
46.1538% difference over OEM FiST IC
9.4122% difference over Mountune IC
Mountune IC
Core Dimensions:
29.25" x 5.75" x 2.5"
Core Volume:
420.47 in
37.145% difference over OEM FiST IC
3.4401% difference over OEM FoST IC
Stock FoST IC**
Core Dimensions:
26" x 6.25" x 2.5"
Core Volume:
406.25 in
33.8129% difference over OEM FiST IC
4.0816% difference over Levels IC
Levels IC
Core Dimensions:
26" x 5" x 3"
Core Volume:
390 in
29.8343% difference over OEM FiST IC
19.6224% difference over Mishimoto Z-Line IC
Mishimoto Z-line IC**
Core Dimensions:
26" x 5" x 3"
Core Volume:
320.31 in
10.3635% difference over OEM FiST IC
Stock FiST IC
Core Dimensions:
27.5" x 5.25" x 2"
Approx. 5lbs
Core Volume:
288.75 in
Core Dimensions:
22" x 7.2" x 3.75"
Approx. 19lbs
Core Volume:
594 in
Cobb IC
Core Dimensions:
27.5" x 6" x 3"
Approx. 13lbs
Core Volume:
495 in
ATP IC
Core Dimensions:
24" x 6.5" x 3"
Core Volume:
468 in
AIRTEC IC
Core Dimensions:
28" x 6" x 2.75"
Core Volume:
462 in
Mountune IC
Core Dimensions:
Core Volume:
420.47 in
Stock FoST IC**
Core Dimensions:
26" x 6.25" x 2.5"
Core Volume:
406.25 in
Levels IC
Core Dimensions:
26" x 5" x 3"
Core Volume:
390 in
Core Dimensions:
26" x 5" x 3"
Core Volume:
320.31 in
