The Koni Sports are adjustable for rebound, so at least that can be set to the Swift springs, but yes, IF the set compression valving (or the lowest rebound setting) of the Konis is WAY OFF of what the Swifts were 'built to'/rated for, it will not be ideal.
WHY I am
still tempted to wait for the GC setup, where I can use ANY coil over spring rate, (and linear rate coil over spring manufacturer, INCLUDING Swift's coil over springs) I desire to match to the Koni's compression valving, for the fronts at least.
Just as a note/opinion; I don't think that Ford changed the damper valving
all that radically between the older ones and the revised latter ones, or at least not far enough out of the range of the Swift springs so as to cause actual
damage to either the spring, or the damper.
So at least in that respect, yes, the Spec R springs will probably be just fine on the '17 and up factory dampers, even long term, or until the factory dampers just plain old 'wear out'.
IF anyone is still worried about this, a call to Swift's tech department would quell any concerns.
