I decided to try my hand at building my own intake instead of purchasing an Injen or one of the other offerings currently on the market. The one thing that did turn me off is the use of a metal pipe for the long run from the MAF to the turbo inlet. I didn't like the fact that heat soak would turn this into an air charge heater (even if it's just a small amount radiated into the intake charge when at speed).
I started my build by ordering a silicone Mountune style induction hose from JS Performance. It looks identical to what Mountune sells and I received it from the UK including shipping and VAT for ?92.46.
I also ordered a MAF adapter from J1 Automotive also in the UK. This was 30 GBP to my door.
I wanted lots of surface area to reduce suction losses so I went with a large K&N filter at 6" ⌀ (long end) 4" ⌀ (short end) by 5" tall. This has a 70mm or 2.75" inlet ID to match the rest of the system. K&N part number RU-4870 is what I used. It was expensive at $46.99 from Amazon.
I also ordered a 45? elbow to use but it turned out not to work as the filter I selected was WAY too large. I ended up ordering a 90? silicone elbow from Amazon for $10 to aim the filter straight down in the hole where the airbox used to be.
I finally received everything and then realized I needed a way to connect the 90? elbow to the K&N. Of course 2.75" pipe is nearly impossible to find locally. I finally found a 2.75" OD (not ID) exhaust pipe and had to make it work.
Below is the nearly finished product. I still need to use my ABS sheets and a heat gun to build a heat shield and potentially a bracket to keep it secure.
The sound is great. Pretty loud actually. It definitely feels more responsive. I want to think it's a butt-dyno miscalibration due to the $ spent and time involved but I believe it's a real thing. After my test drive I started to get worried about how low the filter is to the ground, hydro locking, etc... but after looking at it again the bottom of the filter is a full 5" above the top of that lower IC charge pipe. The filter is also nestled behind the headlight and off to the side of the radiator so I bet it's fairly safe from water. I think the first time it rains I'll rubber band some paper towels to the side of it to see how wet they get.
For those following along, I definitely didn't save money. I'm at $254 including the induction hose, the MAF adapter, the elbow and the filter. I'm hoping that the position of the filter down low as well as some well placed heat shielding will be a net win. I know for sure this is a larger filter (surface area) than anyone else is using.
As long as the COBB filter isn't a restriction in and of itself due to small size, the plastic induction tube they're supposedly using is a win over other offerings right now.
