Someone asked for pics of the lights against a wall at 25 feet (distance Ford specifies for adjustment). Here they are. Lights look a little off axis against the wall, but its not noticable on the photo from behind the wheel.
Updates on my build. I'm going to finally get back to installing more parts I have sitting around. I like to install my parts in groups, so I don't have to pull the same stuff several times to get work done. I installed the pedal spacer from No-Pistons last weekend. For $22.00 this finally resolved my seating position gripes. This spacer, in conjunction with the shift lever extension, a round shift knob, and moving the steering wheel all the way out and up, so I could move my seat back to a comfortable position, has made shifting and driving a real pleasure. The pedal install would probably be really easy for a right-handed person. I am a lefty, so I had to do some contortions to get an air wrench and extensions. No-Pistons provides washer nuts, since the OEMs are really one use only, specialty nuts. I decided to use stainless metric captive nuts and torque them to OEM specs with my inch-pound wrench.
Its kind of hard to take a pic (at least for this lefty), so I only have a few I did.
I have all of the raamat and ensolite I need for my next project (Thanks Rick). I also got some closed cell foam with aluminum one side backing from work, and will be using it for my 2J Racing intake mod. I already received the JMR plug extension. After that, the IC and front crash bar from Dead Hook is on the list, followed up by the Wilwood BBK. Somewhere in between this stuff, I will finally install my flex fuel gage in my glovebox. And I'll have to move my OCC to where the Mountune airbox used to sit. I'm thinking of using a 5/8" copper U-bend to change the hose direction into the intake manifold. I want to keep the engine cover, but that may need to go away, based on where these hoses need to go.
I'm still undecided on whose coilovers I'll end up with, most likely BC from 2JR. Maybe Modbargains.
