I would love to hear this little engine spin that high, has to sound intoxicating!
BUT, RPM kills engines faster than all but a bad tune or wrong gear downshifts, be careful there as the main reason F1 engines are so expensive, to make the RPM to make the power, a major reason they went back to boost(unless they changed again, no TV, not following F1 now, no time, to busy living my dream
One thing many overlook, I have mentioned it in different terms but the basic way to think of it is simple.
1) What RPM do you run the most? Averaged out, over time, nearly always well below peak power levels.
2) What RPM do you find yourself in most of the time when you need quick acceleration? Well below peak, low to midrange.
3) What real power do you have available for most of your real driving and often times in situations like canyon carving, solo, HPDE, etc.....? Mid to upper mid range and some at peak.
4) What numbers do you come up with using a timeline, all the above, etc...what will yield higher numbers? A wider power band with less peak power, you actually have more power more of the time where you spend the vast majority of the time.
5) What car will be faster, more of the time? The answer is in #4.
6) What car will potentially be safer most of the time? Answer is in #4, nice to have power to get out of the way, etc, something I have used hundreds if not thousands of times.
7) What car will benefit from spreading the money around on things like wheels, tires, brakes, suspension, diff, weight reduction, etc instead of mostly on peak power? All cars, most all the time, especially when carefully built as a balanced package.
8) What car will be more reliable, easier to drive in most situations, more overall fun, for most drivers? #7
I like most everybody else love to read about big power numbers, exciting stuff, real world driving fun, I will always take a car setup like #7 with a nice wide power band and less peak power and I have beaten hundreds of cars over the decades that have had more power than they needed, many of which still upgraded other parts but not in a balanced package and balance is the single most important key, to all things, not just cars.
But of course,
"it's your thing, do what your wanna do, I can't tell you, who to sock it to"
I will gladly demonstrate this when I have my car done, sorted out, on track, demo rides in safe areas, etc....for anybody what wants a ride and a select few will get to drive it as well
Have a great day!
Rick
