Yes sir, with Razor's help, I got that part ironed out. Getting rid of the throttle closing tuned out to be the easy part. Making the car drive like stock with those changes made is the tough part. If your not running big boost numbers and/or running them higher in the rpm band, its not very hard to tune out. The harsh difference between a stock or stg3 car running 13-14psi at 6200rpms vs a cyborg (or other ) car running 19-20-21-22psi at 6200rpm is HUGE difference in load ( at least what the ecu calculates as load ). Going so far over ( any amount will do it ) the load limit at that part of the table will close the throttle. If its a little change, just a small change on the throttle tables will fix the issue with no repercussions. But when its such a big jumper over the OTS tune load limits, it requires a good size change in that throttle table, which fixes the throttle closing. But then.... The throttle map is out of wack, lol. So... It takes a while to get the throttle stuff tuned.
On a stock turbo, its not an issue almost at all.
