I have decided that I need a little bass in my music system, no modifications to the stock system, just adding a sub and amp.
I am going to do it myself so that I can get the finish that I want and because where I live I haven't seen any place that would do an install far superior from what I can do so there is no need in paying for it... at least for now.
I will be using:
Subwoofer: Alpine SBR-S8-4
Amplifier: MRV-M500
Speaker level input present in the amplifier but plan on using a line out converter: PAC SNI35, I plan on using both rear speakers for input.
I am going to use a fuse from the fuse-block for the remote turn on and I plan on wiring it so that when the car is turned on the amplifier can turn on and when the car is turned off the amplifier will turn off... to that, I will add an ON and OFF switch so that if I want (for some reason -kids i.e.-) to turn off the amplifier I can do so without having to turn off the stereo.
I used an amp wiring kit SCOSCHE REVOPAK8 and followed the instructions on a previous thread by MKVIIST to bring the power from the battery to the trunk. I already did this step and currently waiting for the amp to be delivered to finish the install.
For speaker wire I will simply use a fairly good quality speaker wire that I purchased in the past from amazon.
I also confirmed that the sub in the trunk still leaves enough space for the kids
The sub doesn't fit underneath like in other posts, so this is probably how I am going to install it using industrial strength Velcro
Cheers!
I will be using:
Amplifier: MRV-M500
Cheers!
