so when I tried using LC for the first time today it holds at 2500 RPMS and does the fuel cutoff, how do I change this?
If you're on the latest software here are the steps (from:
https://cobb.app.box.com/ford-custom-features):
Launch Control has been completely redesigned to offer greater flexibility along with future functionality. Several new requirements and conditions have been added to allow a single calibration to be used on the street, strip, track, and dyno.
Our solution provides two styles of engine speed control. The default is Fuel Cut for those who prefer to build boost while preparing to launch. The alternate is Throttle Cut for those who prefer to launch the vehicle without building boost. The latter method avoids placing undue stress on the engine by utilizing
the OEM Target N control PID systems.
There are multiple conditions that must be met in order for the launch control feature to be used. These can be seen on the diagram above, but are listed below for convenience:
1. Launch Control must be enabled using the “Enable Launch Control (Main)” switch.
2. Burnout mode must not be active (see more about Burnout Mode below).
3. Vehicle Speed from the un-driven wheels must be under the “LC Exit Threshold (VSS)”.
4. Accelerator Pedal Position must be over the “LC Activation Threshold (APP)”.
5. The vehicle must be in neutral, 1st or 2nd gear.
6. The Clutch Pedal Position must be at least partially engaged.
7. To utilize the Fuel Cut limiter, only steps 1-6 are required.
To utilize the Throttle Cut limiter, the Hotswap LC button must be held down.
Once the vehicle is launched and conditions are no longer met the ECU will resume normal operation of
the engine speed limiters.
