Oh it was a process... I had to cut and notch and weld the cross member - there is no way the lights would mount behind the grill otherwise, there is simply no room.
I'll be taking the front end apart for my FMIC install and I'll take some pictures then.
Did you go with the AD08Rs over the A052s because of the deeper starting tread depth, and it's tread pattern making it much better suited for deep standing water than the A052s?
Yes some of those reasons plus I believe from the research I did the AD08Rs should last longer, hopefully can get two summers with 4-6 autocross events per year. Have a new Mazda CX-5 Signature with 2.5L turbo so will be putting less miles on the FiST now
