Nevada
As I was heading to work. I found out one of my taillights went out, when I was stopped at a red light and could see the reflection from the car behind me.
Bull Run
U.S. Army Veteran
Chandler, AZ, USA
I looked that up and found this bit of advice: N-Series valve (with nipple to accept hose) is not recommended for passenger cars with low clearance. Is that of any concern if I've lowered my FiST?
Valve that I have is F106SX I'm lowered by about .75". As you can see in the picture, the valve doesn't stick down that much and the brace and subframe will scrape the ground first.
pixelzombie
Chicago, IL, USA
Rural
I installed my fourth HVAC blend door actuator (YH-1896) today. I have the 5th standing by for the day this one also breaks.
While I was in there, I replaced my buzzing interior temp sensor fan module and added the Euro-market isolator for good measure.
3M5Z-19C734-C = replacement interior temp sensor
BA61-19F647-AA = diffuser adapter (Euro market)
Sam4
West Chester, PA, USA
Dumped a bunch of leaked oil from #1 and 3 spark plug wells while changing out new NGKs. No smoke! Going to have to suck that up next time....if there IS a next time!
Fresno
Checking undercar today and saw this hole. Is there anything that cover it? I know the stock charge pipe has a bracket in front of it but the Whoosh one does not which leave this hole expose to the element. 1000000588.png
