Sometimes, my genius is almost frightening.
The OBD port is cause for lots of thefts, and people run fake ports etc but i thought, what if i just actually remove the port.
So, i bought a solid steel lock box used for keys on the outside of houses, used a hacksaw to slowly make a hole enough to poke the wire through and locked the OBD port inside.
Only way to get it is either by snipping the cord, or angle grinding a LOT - best part is the box cant be pulled out as the cable is too short so the dash would have to be stripped off to even get access to put an angle grinder on it. Has a code lock so i can take off whenever i need the port.
cost me £5 for this box 2nd hand on eBay.
and yes, the drawer still closes.
Let me know your thoughts!
