Error codes p1299 and u1035
España
Hi friends!!! i have a fiesta mk6 with swap to mk7. 5 st, which is giving temperature fault p1299 and u1035, I changed the coolant box sensor, I have checked continuity from the connector to the engine control unit, and everything seems correct! I haven't done the level sensor campaign but it shouldn't fail right? any ideas?,mod
I forgot, the fault appears shortly after turning on the ignition, starting or not starting, whether it's cold or hot, and it goes into limp mode.
in reality the car is not hot, it just thinks it is, turning off the ignition and turning it back on, it shows its real temperature for a while, but the temperature goes back up to the top, red light on the panel and limp mode
C
España
the problem is finally due to the lack of the coolant level sensor, the software was made but nothing was physically installed. Now that I have the pieces, I still have to know how the cables are connected, can someone help me?
Waz2010h
Market rasen
Is there any fix for this? I currently have the same issue
Market rasen
Same problem here, did anyone ever fix this?
I had this problem. I sent it to ford they said it was the sensor, I told them to change it and then changed my mind because they said it would cost £850 and I rang a performance place up that said they would take the software off for £50 but ford tried the sensor and said it was still the same so they said it was wiring. So I took the car home tried to put my imap back on the car and it failed and said return the car to stock. As soon as I did that all warning lights went off, so I would say it's a software fault. I still took it to have the software removed, just make sure the coolant is topped up
California
I topped up the coolant and its fixed! I don't understand why though.. My coolant bottle has no sensor or wires to it. How does the car know its low on coolant?
Now to find why my coolant is disappearing..
Market rasen
I removed the map off the car before going to ford and it didn't make a difference, I put it back on took it back off to see if it would reset it and clear it
If your coolant bottle looks like this, the sensor is in the bottom of the black thing connected to it. In dollars the sensor is around $800
