Positive battery cable clamp replacement
KS
The bolt that is threaded into the nut that tightens down the positive battery clamp chewed up the clamp itself and now when I try to tighten it down, it free spins. My question is, if I order just the clamp does the fuse assembly (terminal block?) come off the clamp and can be re-used? Picture attached is for reference.
Clamp: https://www.tascaparts.com/oem-parts/ford-bolt-battery-clamp-8v5z14450a
