Fiesta ST autocross accident
Las Vegas, Nv
Questions for you guys The high for the day I autocrossed was 55°. So I didn’t have any temperature issues.
Popped the hood open in between runs and had the heater on the whole time. I was using both the front facing vents and the feet vents. Is it better to use all the vents or just the top ones? Which solution would get rid of heat the most?
Las Vegas, Nv
Also, how much fuel are guys running with? 1/4 tank? 1/2 tank? I’m assuming anything in between quarter to half a tank is ok. And 1/8 or less can cause fuel cuts.
hawyee
Active Duty U.S. Air Force
OKC
No
The most I ever manage to fit in my mkv gti was 255. Anything more would’ve required wider fender or fender flares.
Mk7s and even mk8s are common in the class and can definitely fit 265s on a 9" with the right setup, not sure if it's actually better for them to max width though. And yeah when mine was stock I had to blast the heat for longer courses in hot weather but you should be ok without when it's cooler. I usually just use the top ones and close the middle with the outside vents angled out the window. As far as fuel goes if you want to pinch pounds probably a quarter tank but I was never too worried about it.
RAAM
U.S. Navy Veteran
Gardnerville Nevada
I gave up on building a car to a class decades ago after winning a lot of events in the best car in class it got boring. All my cars since then were built to what I wanted them to be and then ran in whatever class I had to. It turned out for me that I liked this much better, especially when I would take 2nd, 3rd, 5th at a national level event in the wrong car and beat most of the right cars, far more satisfying:)
In the early days I had boxes of trophies and plaques and eventually donated them to be reused and never accepted another one.
Rick
(Civic needs all the tire love it can get, helps it feel better because so dang ugly;)
Las Vegas, Nv
That’s crazy. Must be nice running 265’s. Are they running stock fenders?
Thanks for the other advice
Las Vegas, Nv
Rick
That’s how feel now. It got old doing big builds. So I just want to be on street classes with the minimum mods possible.
