Hello all!
Been running through getting my pre-owned 2018 FiST back up to speed. Just this week got a P1450 code for the purge valve so I ordered the fuel feed line assembly that includes the valve (D2BZ-9C047-E).
Today after driving for groceries it stumbled and sputtered for a second when pulling up to my driveway. Now I'm getting a crank no-start condition and its throwing P0087 & P00C6 as well as the old P1450.
Fuel pressure from the sensor is showing around 10psi, and I believe the sensor is working as intended as when i unplug it, no reading is given. I removed the rear seat and cleaned up the pump top to prep for replacement, and I can clearly hear the pump prime in acc mode and send during cranking. The pump has clearly been replaced before as noted by the mangled metal hole.
I ordered a new Low Pressure Fuel Pump, but it wont come in until Friday. Any tips or suggestions on where to check and test while I wait?
Thanks in advance!
Thanks in advance!
