Age old question, 5w20 vs 5w30
Nevada
Hello everyone,
Still a relatively new member of this community, and finally got my 2019 Fiesta ST I was looking for just 13 days ago.
(Updated post in case anyone was following my new member introduction post)
https://www.fiestastforum.com/threads/greetings-from-las-vegas.32519/
With that out of the way, I feel like I'm going to get ripped in half for asking this question. But, I have done my due diligence and searched multiple threads regarding this topic on this forum, and even doing research outside of the forums to see what everyone is saying.
From what I've seen so far...I've learned that (Please correct me if I'm wrong)
1. Apparently the 5w20 weight is used to achieve better mileage...? Or at least that's what Ford was aiming for when they put it on the owner's manual.
2. 5w20 is used mainly for colder climates, but even so people are deciding to go 5w30
I have seen many people either stay true to the 5w20 or change to 5w30. I've also heard some people mention benefits outside of performance for going to 5w30 instead (like less noise and rattle).
I plan to daily the fiesta for the most part and currently reside in Las Vegas, so we're in our colder months right now. But "cold" is only about 45-50 degrees Fahrenheit here. No track use, but like to go for light spirited drives from time to time.
My mind is saying 5w30, and plan to go for this at my local Wal-mart but just want to make be 100% sure before I go forward with it: https://www.walmart.com/ip/Pennzoil...uart/139680614?classType=VARIANT&athbdg=L1102
With all that being said, I turn to you my fellow Fiesta fanatics. Would you go for 5w20, or 5w30? Any input is greatly appreciated!!
San Diego
I'm no expert, but I've been using Pennzoil Ultra Platinum 5w-30 and have been happy with it. However, I've only put on about ~9k miles since I bought my car, so no long term experience. I've only had some fuel issues, unrelated to oil. Here's a good video on the difference of the Ultra Platinum vs Platinum:
View: https://youtu.be/hqBJQ23NFYc?si=ygN7EBaXDTNVL80i
I did spend about 3 months trying to find the best oil and oil weight before my first oil change. I landed on sticking with 5w-30, obviously there's many brands that can be argued to be better than others. What helped me come to a decision for the brand was comparing all of the specs/additives of different oils, and comparing it to what results show are generally better for our engines (and also taking price into consideration) . For reference, I am in SoCal, so no cold weather.
CHAPEL HILL, NC, USA
I believe in sticking with what the manufacturer recommends, which in this case is 5w20. I feel more comfortable with that .
There is some talk that a thin oil like that is recommended for better gas mileage, but I can't believe that a manufacturer would jeopardize the safety of its engines just for some minuscule extra amount of gas mileage.
I've read that modern engines have tighter manufacturing tolerances than engines used to, and that is one reason that viscosities have become lower over time, to be able to get into the tighter spaces. According to an Amsoil blog-
"modern engines are built with tighter tolerances than older engines. For example, the spaces between the crankshaft journals and main bearings are smaller.
Many newer engines also use variable valve timing (VVT) to improve fuel efficiency and reduce emissions. Many systems require the motor oil to flow through tiny solenoid openings to actuate VVT components. Oil that’s too thick to flow through these openings can cause problems and trigger a check-engine light."
I've also seen extensive interviews with some of the engineers who designed our cars, and I was impressed by the thoroughness and level of thought that went into every aspect of it, even small ones. I would hope and think that the same level of care went into a major choice, that of oil viscosity.
Whichever one you choose, you obviously want to use a high quality full synthetic, I don't think that is in debate.
United Kingdom
For the last 7 years I have always used Castrol Edge 5w30 with FoMoCo oil filters. In that time I’ve done 50,000 miles and around 25 track days with no issues, so this oil gets my vote!
Sam4
West Chester, PA, USA
Ask Hyundai about manufacturing for extra mileage. We go thru a ridiculous amount of oil with their DI engine (clean tailpipe!). They've bumped it out to 150k warranty, but no way are they going to accept my oil change paperwork. Don't accuse ford of being any smarter - looking at you EV mustang...
Atlanta
My recollection is that this engine is spec'd for 5w-30 in the EU, AUS, etc. The only place that requires 5w-20 for it is the US for mileage/emissions purposes. So something to consider.
I recently swapped to 30 weight, and it is notably quieter in operation in general driving.
Recall that the manufacturers interest is getting the car certified with the best MPG and emissions rating possible, through the warranty period. After that, they do not incur repair/maintenance costs. For example, look at how many fluids they say are 'lifetime fill', such as early PTU's. They definitely needed the fluid to be replaced, but would make it through warranty period before general failure. After that, so what? It's all a numbers game by the corp actuary's to model potential loss.
