Clunking / chugging sound when cold started (w/video)
Montreal
My Fiesta developed a weird sound on cold starts. It's hard to describe, so I posted a video below where you can really hear it well, especially the later part of the video where I open the door and record under the car. It goes away after a few minutes of idling. I can also confirm that after 20 mins of driving, parking and doing the exact same small revs don't reproduce the sound.
At the same time this sound was starting to develop, an exhaust leak where the flex-pipe on the catalytic converter popped up as well.
I changed the exhaust post catalytic converter with a used, but good condition one. I also just had the flex-pipe on my catalytic converter cut off and replaced at a local mechanic.
After all of this, the sound is still there on cold starts. The mechanic says is shaft end play on the turbo, which I doubt, but could be possible.
What do you guys think? I have not seen other sounds or reports like this on the forum yet, and I'm pretty stumped.
Dialcaliper
San Francisco Bay Area
Have you checked for the noise with the engine bay open? I’d be curious if you can hear it there.
Just a question as the phone audio makes everything sound a bit odd - are you talking about the “snort/raspberry” noise right as you begin revving, or the kind of “warbling” sound it makes especially as it settles back to idle?
If it is indeed anything to do with the turbo you can experiment by unplugging the diverter valve and/or wastegate solenoid and see if the noise changes character on revving.
Are you sure it is noise out the exhaust? Can you hear it at all at the tailpipe?
How many miles on the FiST? did you take off the inlet Hose on the compressor housing and inspect the Turbo for shaft play? This could also be the DMF starting to give up the ghost.
Volumetrik
Montreal
Thanks for the replies. It's a 2014 with 140k KM's.
Yes, I'm talking about the snort/rasp sound when I begin to rev. I'd have to get someone else to stand at the back of the exhaust and tell me if they hear it. I'll report back on that soon. I'll try the two avenues @Dialcaliper mentioned, I'll report back as well.
Yes, next step is to physically inspect the shaft end play. Interesting comment about the Dual Mass Flywheel possibility @TyphoonFiST . How would I check that? I'd have to pull the trans and inspect it physically, or there is another way?
Volumetrik
Montreal
Sounds pretty similar to yours. The only thing I want to rule out is that there is no remaining exhaust leak. I'll inspect all the connection points from the manifold to the catback.
Volumetrik
Montreal
Here is a new video from an overnight cold start. The noise is different and somehow even worse.
This sounds to me like an exhaust leak, what would you guys say? My phone crashed and cut the recording short, but the extra ringing sound disappears after a while.
When I get back from my road trip, I'll take time to inspect the turbo manifold connection points and see if any studs have loosened over time.
Volumetrik
Montreal
To follow-up on this, I'm confident I have found it the problem.
TL;DR : Broken stud between the block and the exhaust manifold.
Overall picture with context.
Closeup of the broken stud.
Since the stud looks to be broken after the center portion of the stud, my chances could be a bit higher since no torque is still applied on it.
I'll have to order a new oil feed tube it seems...
Symptoms from the service manual seem to indicate this as well.
I'll follow up in a couple of weeks when I receive the parts and perform "the extraction".
Volumetrik
Montreal
Just wanted to confirm that the extraction of the broken studs (two actually, the one below was also broken) solved the issue.
I'll have more details in my build thread, but the short of it is, I put a new manifold gasket, new studs and nuts. Everything torqued to spec, and the problem is now fixed.
Volumetrik
Montreal
Easy Out, or some other method of extraction?
Here is the post in detail.
We used this tool. We had several others, like the Grabit and Grabit Pro series. It worked great for one of the two studs. The other was starting to approach scary territory of torque required and we decided not to proceed and simply tap the existing material in the head. This stud of course is going to be less strong, but it did hold in the end.
Unfortunately, it later broke into the turbo manifold housing, requiring us to use a carbide burr bit to clear it out before drilling to size and re-taping.
